It is currently Sat Aug 09, 2025 11:04 am
PostPosted: Sun May 21, 2017 10:26 am
Last Name: Livermore
State: Minnesota
I think I have my technique basically dialed in.
After many guitars though, I am seeking some advice.
How do I get the finish to lay down flat and smooth. This has a bit of texture that I describe as almost leathery.
I hope surface prep is npt the issue because This sucker was flat and smooth and PERFECT.
Any ideas will be appreciated.
PostPosted: Sun May 21, 2017 11:57 am
I have the same problem and what works for me is a good level sanding before the last two or three sessions. Then glazing with a stiff hard stroke. It's not the way the old world masters do it but it works for me ;)
These users thanked the author jfmckenna for the post: Glenn_Aycock (Wed May 24, 2017 6:52 am)
PostPosted: Sun May 21, 2017 5:26 pm
State: Minnesota
Robbie O'Brian chimed in and let me know I am piling too much shellac on.
He too recommended a level with sandpaper after a good cure and buff out.
PostPosted: Sun May 21, 2017 6:46 pm
Dave,
Maybe not enough time between sessions.
PostPosted: Sun May 21, 2017 9:06 pm
State: Minnesota
Yeah yeah yeah Pat. I know. Patience.
How long is that gonna take?
These users thanked the author Dave Livermore for the post: Hesh (Tue May 23, 2017 3:37 pm)
PostPosted: Tue May 23, 2017 1:25 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
get in contact with David Laplante.
he's on this forum.
Mike Collins
PostPosted: Tue May 23, 2017 6:58 pm
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
Yep, I do the same. A good level sanding before the last few sessions and use a pretty dilute shellac so it really puts out a thing layer. Robbie's point is good as well; if you are just applying that ghosty film vapor that disappears it really has no choice but to go on smooth,
PostPosted: Tue May 23, 2017 11:34 pm
The old world masters might not level, but I know Eugene Clark did! Tom Bills teaches his method in the Luthier's Edge French Polishing course.
These users thanked the author James Orr for the post: Imbler (Wed May 24, 2017 3:36 am)
PostPosted: Wed May 24, 2017 2:29 pm
I recall a lecture by Richard Brune printed in GAL in which he mentioned to sand with fine grit dry after building. I do not recall if that was between building coats or just prior to spiriting off.
Users browsing this forum: Cal Maier and 38 guests
